69matrix69
May 18, 2023Tutor
RBKE960 power adapters needed or model number for power adapter needed
I just moved from PA to SC and my movers lost some of my things as they shipped a 2nd load with my stuff. I unpacked my Orbi RBKE 963 router and 2 satellites but I can't find the power adapters for a...
- Apr 23, 2024
Ok, Good news, this particular PS arrived to day and has correct sized plug that works for the 960 series:
https://www.amazon.com/Kircuit-Compatible-332-11588-01-3321158801-PY321200536/dp/B0CH3FW3HS
I was only able to connect and power ON for a short while. I'll be sending this back.
Hopefully this is a good alternative for users that may need one if the stock PS goes back or gets lost or damaged.
This may work for NGs CAX80 gateway modem and RAXE500 router as well since these two have same larger barrel center pin as the 960 has.
swong801
Apr 02, 2024Initiate
Has anyone had success on finding a replacement for these. I have also been searching for replacement power supplies that have that large barrel connector. I have not been able to find anything that matches.
Apr 02, 2024Guru - Experienced User
You'll need to contact NG about that.
- CrimpOnApr 02, 2024Guru - Experienced User
Is this one that you have tried?
- FURRYe38Apr 02, 2024Guru - Experienced User
Would be worth checking out if it has the right amps and plug in for RBR/RBS. Need 3Amps on the line.
It's the only one that specifically mentions the RBSE960 satellite, over twice the cost of this one:
Irritating that they do not mention the actual specs.
