69matrix69
May 18, 2023Tutor
RBKE960 power adapters needed or model number for power adapter needed
I just moved from PA to SC and my movers lost some of my things as they shipped a 2nd load with my stuff. I unpacked my Orbi RBKE 963 router and 2 satellites but I can't find the power adapters for a...
- Apr 23, 2024
Ok, Good news, this particular PS arrived to day and has correct sized plug that works for the 960 series:
https://www.amazon.com/Kircuit-Compatible-332-11588-01-3321158801-PY321200536/dp/B0CH3FW3HS
I was only able to connect and power ON for a short while. I'll be sending this back.
Hopefully this is a good alternative for users that may need one if the stock PS goes back or gets lost or damaged.
This may work for NGs CAX80 gateway modem and RAXE500 router as well since these two have same larger barrel center pin as the 960 has.
JAson-TT
Apr 29, 2024Tutor
AC adapter for Netgear Orbi 960 970 RBKE96 , RAXE500 / RAX200 wifi-7 router, here is the best one I found.
https://www.amazon.com/dp/B00IFWXZDE
19V ac adapter
- FURRYe38Apr 30, 2024Guru - Experienced User
Have you confirmed that it actually works with the bigger pinned units?
I confirmed this one does work and supports the bigger pinned units:
- JAson-TTApr 30, 2024Tutor
Yes, confirmed, I have bought one for my NETGEAR Nighthawk CAX80, yes ,with the bigger pinned
- swong801May 03, 2024Initiate
I bought one of these and it has been working great for the past week or so now. It has the larger pin that fits perfect. https://www.amazon.com/dp/B0CD7B6FG9?psc=1&ref=ppx_yo2ov_dt_b_product_details
