DodgeDeBoulet
Mar 19, 2022Apprentice
RBKE963 - Satellite IP Address Assignments
I've turned off the DHCP service on the Orbi router in favor of using a Pi-Hole; it's directly connected to the router via Ethernet. I've created static leases on the Pi-Hole for the MAC addresses an...
DodgeDeBoulet
While it's nice to know that the IP addresses won't change, it's especially convenient that with the Pi-Hole, the hostnames are also resolved. If one is supplied in the DHCPREQUEST it's automatically added to local DNS, but if you create a lease you can also change the name associated with the address and it will use that instead.
Unfortunately, the Orbi satellites don't provide a host name in the DHCP request (on the Pi-Hole they show up as "unknown" in the DHCP page), but when creating their reservations I was able to add names to them. So my satellites are now known as livingroomorbi.lan and mediaroomorbi.lan.
Mar 19, 2022Guru - Experienced User
There you go.
