Fishon99
Oct 09, 2024Aspirant
RBKE963 - using only one of two satellites
I am considering purchasing RBKE963 with router and two satellites as it is on sale. My house is 3000 sq ft so I only need the router and one satellite in my current set up. I have an exterior buil...
Oct 09, 2024Guru - Experienced User
Yes, you can use only one RBS for your needs.
However I would recommend that for any FW updates for the system, that you bring the 2nd RBS and put it online and update both RBS first, then the RBR lastly to what ever FW version maybe available. Then you can put the 2nd RBS away.
Can use the 2nd RBS in a wired configuration out to the remote location as a suggestion:
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System 📡 ‌‌🛰️
- Fishon99Oct 09, 2024Aspirant
Thank you for the feedback and making me think about keeping the firmware in sync
Have a great day
