Kad2
Dec 02, 2021Follower
RBKE963 2.5ghz ports
I am looking to buy the orbi 6e mesh system rbke963 and need to know if the 2.5ghz port can be used to link a switch at 2.5ghz speeds or can it only be used as a backhaul port to the satellites? I c...
Dec 03, 2021Guru - Experienced User
ghzport can be used to link a switch at 2.5ghzspeeds or can it only be used as a backhaul port to the satellites? Yes. I currently have a nighthawk ax router with its 2.5ghz port connected to a high speed nighthawk switch and want to be able to keep that 2.5ghz connection with the orbi. Yes. The manual I downloaded was not clear about it. There are 2.5Gb LAN port on each RBS and the RBR. There is not 2.5Ghz ports. :smileywink:
