Kad2
Dec 02, 2021Follower
RBKE963 2.5ghz ports
I am looking to buy the orbi 6e mesh system rbke963 and need to know if the 2.5ghz port can be used to link a switch at 2.5ghz speeds or can it only be used as a backhaul port to the satellites? I c...
TC_in_Montana
Dec 03, 2021Virtuoso
Kad2 wrote:I am looking to buy the orbi 6e mesh system rbke963 and need to know if the 2.5ghz port can be used to link a switch at 2.5ghz speeds or can it only be used as a backhaul port to the satellites? I currently have a nighthawk ax router with its 2.5ghz port connected to a high speed nighthawk switch and want to be able to keep that 2.5ghz connection with the orbi. The manual I downloaded was not clear about it.
I don't like how the user manual describes it either.
However, with that being said, I have a switch connected to the 2.5G port on the router and it works with no issues. It is not a 2.5G switch, but rather a 1Gbps switch (Netgear GS108Ev3) but having no issues.
I would think that if it is working with a 1Gbps switch, then it would work as well with a 2.5Gbps switch.
- FURRYe38Dec 04, 2021Guru - Experienced User
It should be backwards compatible. However Having mine connected, I used the 1Gb ports with a 1Gb switch just for same rate operation. One or these days I'll get a 2.5 Gb switch system in...still kinda spendy.
