jhmoser15
Dec 03, 2021Guide
RBKE963 and Homekit
Anyone using the IOT SSID and only 2.4g with home kit devices. It seems that homekit devices are going unresponsive. I am running the system in AP mode.
Dec 03, 2021Guru - Experienced User
I'm not.
Has the Orbi system AND IoT devices been powered OFF for 1 minute or more?
I'd power everything OFF, then back ON with the Orbi system first, then IoT devices after that.
How many devices do you have connected?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What is the CTS value set for on the RBR? Under Advanced Tab/Advanced Settings/Wireless Settings
