jhmoser15
Dec 03, 2021Guide
RBKE963 and Homekit
Anyone using the IOT SSID and only 2.4g with home kit devices. It seems that homekit devices are going unresponsive. I am running the system in AP mode.
Mikey94025
Dec 07, 2021Hero
CrimpOn wrote:I understand that customers have been asking for a dedicated WiFi network for IoT devices for years, partly to make connecting devices easier and partly to 'separate' IoT devices from the primary network. When this new Orbi replaces an existing WiFi system that supported IoT devices on the primary network, all of those devices will have been configured to use the primary SSID. If this new IoT WiFi network has a different SSID, then every one of those existing Homekit devices will continue to connect to the primary WiFi network until the user reconfigures them one-at-a-time.
According to the AXE user manual the IoT network has a different SSID. I am still waiting for my unit to arrive, but I am considering using my current Orib SSID + credentials for the AXE's IoT network and configure it only for 2.4Ghz. So by default, all existing devices in my home will go on the IoT network.
I'll create a new SSID for AXE's primary network and set it to WPA3 (only). Only my main devices need to be reconfigured, like phones and streaming devices. I also have some 5Ghz-compatible Nest cameras that I may also reconfigure.
Dec 07, 2021Guru - Experienced User
The IoT can be any SSID name. It's just a separate 2.4Ghz only radio.
- jhmoser15Dec 07, 2021Guide
First my IOT SSID is different then the base network. I have done the things above and still seeing the issues.
- FURRYe38Dec 07, 2021Guru - Experienced User
Has the Orbi system AND IoT devices been powered OFF for 1 minute or more?
I'd power everything OFF, then back ON with the Orbi system first, then IoT devices after that.How many devices do you have connected?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?
What is the CTS value set for on the RBR? Under Advanced Tab/Advanced Settings/Wireless Settings
House 3k SF
I have powered everyothing off as per below.
I have fios 500/500 and my router is a edgemax 12P
my satellites are over 30ft apart
the default 64.
