jhmoser15
Dec 03, 2021Guide
RBKE963 and Homekit
Anyone using the IOT SSID and only 2.4g with home kit devices. It seems that homekit devices are going unresponsive. I am running the system in AP mode.
Dec 08, 2021Guru - Experienced User
Is the Orbi system in router or AP mode?
jhmoser15
Dec 08, 2021Guide
AP mode
- FURRYe38Dec 08, 2021Guru - Experienced User
Can you connect one of the HomeKit devices to the main wifi network SSID and see if it connects and remains connected or if it allso stops responding?
- jhmoser15Dec 08, 2021Guide
I have done that and they drop, but not sure if it is related to them only support 2.4, where the main network has both 2.4ghz and 5ghz turned on. FYI I had an RBK853 system and did not have these issues.
