DodgeDeBoulet
Jul 29, 2022Apprentice
RBKE963 As Access Point
The on-line help via the Web UI in the 960 series router is not very helpful on this subject. Can I assume that the RBRE963 in AP mode will still support the satellites? I'd like to replace the r...
Jul 29, 2022Guru - Experienced User
Yes.
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode
DodgeDeBoulet
Just a nitpick here: Neither of the KBs you link to specifically state that the satellites will continue to work with the router in AP mode. The router's "Learn more" link says nothing on the subject either and could easily be interpreted that the router itself is the only device you can connect to when in AP mode:
Fortunately, the Youtube video (sort of) gives a graphical reassurance that they do.
I also understand that the Guest network is still available on the Orbis in AP mode, as posted by others on this forum and contradicting the KB article. But there's no documentation describing what happens to the (non-isolated, grrrr) IoT network.
Thank you, though, for finding something that confirms the satellites remain functional 😁
