DodgeDeBoulet
Mar 07, 2022Apprentice
RBKE963 Device Incompatibilities
Received my RBKE963 router and 2 nodes last week. After encountering some shortcomings with the DHCP functionality, I disabled it in favor of a Pi-Hole. Not really germaine to the issues I'm experien...
Mikey94025
Mar 07, 2022Hero
What Security setting(s) do yo have for your main/unified network as well as the IoT network? Have you tried disabling AX mode for 2.4Ghz?
My main RBKE963 network is set to WPA2-PSK [AES] + WPA3-Personal [SAE], but I disabled AX mode for 2.4 Ghz and my IoT network is set to 2.4Ghz only / WPA2-PSK [AES]. I use the IoT network for a handful of difficult, older wireless devices that don't see or work well with the main AXE wireless network.
- DodgeDeBouletMar 07, 2022Apprentice
Mikey94025 wrote:What Security setting(s) do yo have for your main/unified network as well as the IoT network? Have you tried disabling AX mode for 2.4Ghz?
I have not tried disabling AX on the 2.4GHz network, but I will. I don't want to do it right now, since I don't know whether that will result in a reboot of the ORBI(s) and that's a little disruptive in this household.
I'll report back with my results.
Unfortunately, disabling AX on the 2.4GHz radio made no difference; the iPad is still unable to connect.
It acts like it's going to connect to the IoT network, but complains that the passphrase is incorrect. I do use a long and complex passphrase for that SSID, but none of the IoT devices have an issue with it (and changing it to something shorter would be a huge pain in the a$$).
For security, I have the unified network set to WPA2-PSK [AES] + WPA3-Personal [SAE]; for the IoT network I have WPA2-PSK [AES].
- FURRYe38Mar 07, 2022Guru - Experienced User
I saw same thing with my iPhone 6sP two years ago with my Orbi 8 series when they had mixed mode enabled. NG removed the mixed mode option back then.
I have raised the issue with NG for review. No idea if or when something will change. It would be nice to be able to set WPA2/AES only.
