808stateofmind
Jan 03, 2024Star
RBKE963 firmware
How can we get a hold of the beta or test firmware?
No.
Something wrong with your system?
- I wouldn’t say something wrong with my system, per se. but I do notice that devices connected on the main network, have a hard time with 2.4 GHz. So you have to use the IOT network but I don’t really like using it a whole lot because there’s lack of security there. Maybe they should implement WPA3 on the IOT side of things. Because I noticed using the guest network and setting up that way all the options are available. So I was just curious if there was beta test files.
808stateofmind wrote:
.... I do notice that devices connected on the main network, have a hard time with 2.4 GHz.Have you tried troubleshooting that?
Start with expanding on what you mean by "a hard time with 2.4 GHz".
Devices don't connect? Lose the connection? Are slow?
All devices? What are they?
Have you tried tweaking the wifi bands on 2.4 GHz?
Is this with the router? A satellite?
