stig911t
Aug 20, 2022Aspirant
RBKE963 has slow ethernet performance
Got 2 gig fiber installed and getting 2.3 gig up and down on the frontier provided Sagecom device. I plugged the orbi in using the same cables and only get 1.7 (at most) usually 1.2 down and 2.3 up. A...
Aug 20, 2022Guru - Experienced User
What is the model# of the Internet Service Providers modem/ONT the NG router is connected too?
Are you using the 2.5Gb LAN port on the back of the RBR to test speeds with a wired PC connected and using Ooklas installable speed test app on the PC?
Is the PC supporting of having a 2.5G or higher ethernet adapter?
What wireless devices do you have?
CAT# lan cable are you using? CAT6A STP cable is recommended.
