stig911t
Aug 20, 2022Aspirant
RBKE963 has slow ethernet performance
Got 2 gig fiber installed and getting 2.3 gig up and down on the frontier provided Sagecom device. I plugged the orbi in using the same cables and only get 1.7 (at most) usually 1.2 down and 2.3 up. A...
Aug 20, 2022Guru - Experienced User
What is the model# of the Internet Service Providers modem/ONT the NG router is connected too?
Are you using the 2.5Gb LAN port on the back of the RBR to test speeds with a wired PC connected and using Ooklas installable speed test app on the PC?
Is the PC supporting of having a 2.5G or higher ethernet adapter?
What wireless devices do you have?
CAT# lan cable are you using? CAT6A STP cable is recommended.
stig911t
It has the latest firmware. The ONT is FRX523.
I’m using cat6a for both cables. I’m using the web version. Works for the frontier router.
It’s pretty apples to apples. Literally one device hooked up to 2.5gig port for each test and I just swap cables out.
- FURRYe38Aug 20, 2022Guru - Experienced User
Try using the 2.5Gb LAN port on the back of the RBR to test speeds with a wired PC connected and using Ooklas installable speed test app on the PC...
Is there a built in router on the ONT? if so, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode- stig911tAug 20, 2022AspirantReading some of the forums it seems that users don’t have access to this ONT or I haven’t searched hard enough yet.
- Mikey94025Aug 20, 2022Hero
Is there a model number for the Frontier router or is that the same as your FRX523? If the device upstream of the Orbi is a router, then adding the Orbi in Router Mode will duplicate the routing functionality (Double NAT) and produce inefficiency that can account for your speed difference.
If the device upstream of the Orbi allows multiple LAN devices to be connected then it is doing routing. You can alternatively run the Orbi in Access Point (AP) mode. Alternatively, find a way to put the upstream router into "bridge mode" and let the Orbi do the routing in Router Mode.
If the device upstream of the Orbi is not a router and only one LAN device can be connected to it, then I don't know what could be the problem. I don't know what the max bandwidth supported by the Orbi RBKE963 is -- It can certainly support 1Gbps (with unnecessary stuff kept off like the speed test, Armor, access controls, traffic meter) but I don't recall reading here of people doing 2Gpbs.
