stig911t
Aug 20, 2022Aspirant
RBKE963 has slow ethernet performance
Got 2 gig fiber installed and getting 2.3 gig up and down on the frontier provided Sagecom device. I plugged the orbi in using the same cables and only get 1.7 (at most) usually 1.2 down and 2.3 up. A...
stig911t
It has the latest firmware. The ONT is FRX523.
I’m using cat6a for both cables. I’m using the web version. Works for the frontier router.
It’s pretty apples to apples. Literally one device hooked up to 2.5gig port for each test and I just swap cables out.
Aug 20, 2022Guru - Experienced User
Try using the 2.5Gb LAN port on the back of the RBR to test speeds with a wired PC connected and using Ooklas installable speed test app on the PC...
Is there a built in router on the ONT? if so, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode
