stig911t
Aug 20, 2022Aspirant
RBKE963 has slow ethernet performance
Got 2 gig fiber installed and getting 2.3 gig up and down on the frontier provided Sagecom device. I plugged the orbi in using the same cables and only get 1.7 (at most) usually 1.2 down and 2.3 up. A...
Aug 21, 2022Guru - Experienced User
Try using the 2.5Gb LAN port on the back of the RBR to test speeds with a wired PC connected and using Ooklas installable speed test app on the PC...
Is there a built in router on the ONT? if so, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode
stig911t
Aug 21, 2022Aspirant
Reading some of the forums it seems that users don’t have access to this ONT or I haven’t searched hard enough yet.
- Mikey94025Aug 21, 2022Hero
Is there a model number for the Frontier router or is that the same as your FRX523? If the device upstream of the Orbi is a router, then adding the Orbi in Router Mode will duplicate the routing functionality (Double NAT) and produce inefficiency that can account for your speed difference.
If the device upstream of the Orbi allows multiple LAN devices to be connected then it is doing routing. You can alternatively run the Orbi in Access Point (AP) mode. Alternatively, find a way to put the upstream router into "bridge mode" and let the Orbi do the routing in Router Mode.
If the device upstream of the Orbi is not a router and only one LAN device can be connected to it, then I don't know what could be the problem. I don't know what the max bandwidth supported by the Orbi RBKE963 is -- It can certainly support 1Gbps (with unnecessary stuff kept off like the speed test, Armor, access controls, traffic meter) but I don't recall reading here of people doing 2Gpbs.
- stig911tAug 21, 2022AspirantThe router is a Sagecomm fast 5920.
FRX523 is the ONT and I don’t think I can gain access to it. There are some threads on Reddit suggesting the FRX523 puts out a wifi signal but others were disputing that or saying that is only for the techs to use to diagnose/troubleshoot. The router has all the dhcp settings and everything enabled so if the ONT to Orbi is double nat I’d assume the ONT to Sagecomm would be too.
I thought about connecting the orbi in ap mode but haven’t done it yet. There is a 2.5gb ethernet port on it right beside the 10gig wan so I’d assume it can do it. The other oddball thing is I’ve seen the orbi be able to hit the same upload speed. So in my mind at least it is like there is a limitation or something is not configured right on the downstream end.- FURRYe38Aug 21, 2022Guru - Experienced User
Need to see if you can remove the sagecom router and connect the RBR directly to the ONT. If the sagecom is in the middle of the ONT and the RBR, this will be a factor in this problem.
