ArunGupta
Oct 29, 2022Apprentice
RBKE963 How to change the satellite backhaul channel?
When I run the Orbi app, under WiFi analytics, it shows that channel 40 is most congested channel with poor/average performance. It also shows that Current Channel is 40. On some digging, I suspect t...
Oct 29, 2022Guru - Experienced User
You can't change the backhaul channels. And it usually is the higher 4ghz channels for backhaul with the lower used for the fronthaul
CrimpOn
User Manual page 148:
https://www.downloads.netgear.com/files/GDC/RBKE963/RBRE960_RBSE960_UM_EN.pdf
Backhaul Channel:
NA and PR - 157
WW and JP - 108
