madger
Nov 26, 2022Tutor
RBKE963 limited wifi channels
First off is there a way to separate the 2.4 and 5 ghz? i am able to separate the 6ghz. also the 5ghz channels are limited to 36 through 48, which are very congested in my area, does orbi have acce...
CrimpOn
Nov 26, 2022Guru - Experienced User
If by "separate the 2.4G and 5G" you mean assign different WiFi SSIDs to them, then no. Orbi routers do not support this.
madger wrote:
5ghz channels are limited to 36 through 48, which are very congested in my area, does orbi have access to the higher 5ghz channels?
There are only two 80MHz wide groups of 5G channels available in North America, 36-48 and 149-161. Orbis use the lower frequency for user facing channels and the upper group for the connection between router and satellites ("backhaul").
https://en.wikipedia.org/wiki/List_of_WLAN_channels
And, yes. that group of channels is extremely congested.
As a point of interest, selecting a specific 5G channel means that the Management Frames used by the router will be on that single 20MHz wide channel. The router still uses channels 36-48 if they are open in order to maximize transmission speed.
- madgerNov 26, 2022Tutor
Thank you.
- FURRYe38Nov 27, 2022Guru - Experienced User
If you have a area thats is congested with nieghboring wifi, try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.- madgerNov 27, 2022Tutor
My house is 1700, main router is centered, the satellites are at opposite ends of the house, 30ft each from main at least also through a couple of walls, the system works great, coverage is great, im just used to nighthawk routers. i changed from a raxe500 to this this orbi mainly for the 10gig input.
