Remyh
Apr 08, 2023Tutor
RBKE963 one lan port not working
Bought the RBKE963 to replace my Orbi 750, because I upgraded my internet to a 1G fibre and because I’m very satisfied with the Orbi routers. At least that’s what I expect, because I can’t afford food...
Apr 09, 2023Guru - Experienced User
Which LAN port are you seeing the problem with? Is this the 1Gb port or the 2.5Gb port your connecting too?
Do other ethernet connected devices have this problem as well?
What CAT# lan cable are you using? CAT6 UTP is recommended for 1GB ports, CAT6A STP is recommended for the 2.5Gb port.
