Remyh
Apr 08, 2023Tutor
RBKE963 one lan port not working
Bought the RBKE963 to replace my Orbi 750, because I upgraded my internet to a 1G fibre and because I’m very satisfied with the Orbi routers. At least that’s what I expect, because I can’t afford food...
Apr 09, 2023Guru - Experienced User
Which LAN port are you seeing the problem with? Is this the 1Gb port or the 2.5Gb port your connecting too?
Do other ethernet connected devices have this problem as well?
What CAT# lan cable are you using? CAT6 UTP is recommended for 1GB ports, CAT6A STP is recommended for the 2.5Gb port.
Remyh
Apr 09, 2023Tutor
Hi thx for the reply!
I don't use the 2.5G, but one of the 1G lan ports (numbered 1 to 3 here), with cat 6 cable. (I also get 950 mbit speeds between lan devices and speedtest.net)
If I use nr 1 (it is connected to a managed switch and there spread to the other LAN devices), the problems arise and when using nr 3 no problems whatsoever: the correct speed and latencies etc. I checked the router if any blockages were initiated. But on the other hand: WiFi connections just worked. It was only for LAN-connected machines that browsing was not possible, on all of them (sometimes a page 'leaked' through this invisible wall, so 99% blocked. Very strange) And very peculiar: the only LAN device which worked was a Google Camera, that made me thinking it maybe was a port problem.
I tried to revert to the previous firmware, (.5) but it didn't make any difference. Only changing the port on the Orbi.
