Remyh
Apr 08, 2023Tutor
RBKE963 one lan port not working
Bought the RBKE963 to replace my Orbi 750, because I upgraded my internet to a 1G fibre and because I’m very satisfied with the Orbi routers. At least that’s what I expect, because I can’t afford food...
Remyh
Apr 09, 2023Tutor
Hi thx for the reply!
I don't use the 2.5G, but one of the 1G lan ports (numbered 1 to 3 here), with cat 6 cable. (I also get 950 mbit speeds between lan devices and speedtest.net)
If I use nr 1 (it is connected to a managed switch and there spread to the other LAN devices), the problems arise and when using nr 3 no problems whatsoever: the correct speed and latencies etc. I checked the router if any blockages were initiated. But on the other hand: WiFi connections just worked. It was only for LAN-connected machines that browsing was not possible, on all of them (sometimes a page 'leaked' through this invisible wall, so 99% blocked. Very strange) And very peculiar: the only LAN device which worked was a Google Camera, that made me thinking it maybe was a port problem.
I tried to revert to the previous firmware, (.5) but it didn't make any difference. Only changing the port on the Orbi.
Remyh
Apr 09, 2023Tutor
NB: I used the exact (where applicable) settings on the Orbi 753 and the same topology. It was just replaced by the 963.
