gurnio114
Nov 27, 2021Aspirant
RBKE963 poor connection to Nest cameras
Had a nighthawk R8000 in a 3 level approximately 2500 sq foot ski townhouse. Eufy cameras, roku, nest cameras, etc all worked well with the exception of occasional drop outs on the cameras farthe...
Nov 27, 2021Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Try channel 1 and 40. What I have mine set for.
Are you using the IoT radio or the main radio for all your cameras?
I don't have NEST cameras, however all my 4 D-Link cameras have been working well with the 9 series since it got installed. Zero issues.
I have seen others with NEST product issues. Including NEST thermostat controllers. My 3rd gen has been ok on the 9 series. I found 1 low battery on it about a week ago. Was first time I saw that since the 9 series went online. Haven't seen a low battery it since. Was worse on my 8 series system. NEST products have always been problematic with Orbi systems.
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
- Mikey94025Nov 27, 2021Hero
I would not assert that (all) Nest products have always been problematic with Orbi systems, unless you have the data to support such a broad claim. IMO it's only the Nest thermostat where many Orbi customers have had low battery issues and now use the Guest network or a spare router. My other Nest cameras and Nest Protects have worked fine with my Orbis and I have not observed any more issues reported here in the Orbi forums.
Nest cameras can connect at 5Ghz and 2.4Ghz. If you're using the IoT network then it is 2.4Ghz and should have better range than 5Ghz. With the older Orbi AX system many 2.4Ghz devices worked better with CTS/RTS Threshold set to 2347 vs. the 64 default that Netgear uses, so you might try that and see what happens.
- gurnio114Nov 28, 2021Aspirant
I will try that, thanks.
Strange that such a high end product has known issues with a very popular camera system, and that (outside of these and other technical fora) it's not made known to the consumer.
I'm certainly no stranger to configuring stuff, but bought this thinking I could just use the same SSID and password that my nighthawk used and things would work. Naive, I know.
Would it work to use old R8000 as wired AP with same SSID and PW in areas with nest cameras (they seemed to play well together) or would that cause problems with othe devices.
Frankly, for the same money, could have had a decent Ubiquiti system. Was hoping this would be turnkey.
Caveat Emptor
- FURRYe38Nov 28, 2021Guru - Experienced User
Also placement of the RBR and RBS in relation to the cameras as well can be a factor.
I found my one NEST controller for some reason didn't like being too close to my RBR 8 series. When I moved the RBR to a much farther location, the nest stopped giving low battery and remianed connected. I've done alots of troubleshooting, debugging and log collection for NG on with NEST controllers over past two years. Part of these issues seen deals with devices bouncing around trying to find and lock on to the signal. Before on your 8000 series, you only had two signal and if you didn't use smart connect, then it was easy for any device to lock on and remain connected. With Orbi or ANY Mesh system that uses smart connect all the time and having two or more wifi signal sources, devices now have many signals that they have to figure out which one is the best to lock on and to connect too. So placement of the RBR and RBS and devices is key to helping devices connect to MESH systems. Just can't place it and think it should work. Most cases it should and agree it should work, howver with MESH systems, there is a bit more to it then just turning it ON or turn key.
Caveat Emptor
