Baroen
Jan 14, 2022Follower
RBKE963 satellite options
I recently installed the Orbi 963 with two satellites in our rather large house. It replaced a Google nest system with 7 pucks that was constantly dropping signal. The 963 reaches everywhere except ...
Mikey94025
Jan 14, 2022Hero
Baroen wrote:I recently installed the Orbi 963 with two satellites in our rather large house. It replaced a Google nest system with 7 pucks that was constantly dropping signal. The 963 reaches everywhere except a Rachio irrigation controller and a couple of Kasa switches down in a wine cellar. They worked previously with a Google puck in there. Rather than getting one of the pricey 963 satellites to put in there is there another option? Would a satellite from the Orbi 853 or 753 work?
It seems you should just bite the bullet and add another satellite to your mesh system to provide generic coverage throughout the house. :-)
Have you already confirmed that the Rachio and Kasa switches are merely out of range vs. have wireless compatibility issues? I found that the 963's IoT network set to 2.4Ghz worked for most, if not all, my older wireless compatibility devices that struggled with the earlier AX and AC systems. I even tried setting the IoT network to [TKIP] + [AES] for a bit to maximize compatibility, though it's back to [AES] only right now.
Jan 15, 2022Guru - Experienced User
Its nice having support for mixed WPA2 and 3 now.
