Anzenchitai
Jul 19, 2022Aspirant
RBKE963 too slow
My WiFi 6E system is using the latest firmware and I have changed the channel to the less congested channel. Everything was fine right after changing the channel. But after a day or so it is very slo...
Jul 19, 2022Guru - Experienced User
What actual speeds are you getting?
are you testing over 2.4ghz? 5ghz?
do wired speeds drop?
Anzenchitai
Is there a way to setup the RBKE963 and SRR90 to auto reset everyday at 4am? I think resetting the router will help flushing memory and keeping the network faster. Yes, I m using 2x routers and 2x SSID with 1x cable modem. ISP is providing 2x IP for me.
Thanks in advance.
