Anzenchitai
Jul 19, 2022Aspirant
RBKE963 too slow
My WiFi 6E system is using the latest firmware and I have changed the channel to the less congested channel. Everything was fine right after changing the channel. But after a day or so it is very slo...
Jul 19, 2022Guru - Experienced User
Are you using the Choose FIle button or the photo camera icon on the post tool bar?
- AnzenchitaiJul 19, 2022Aspirant
I m using Choose Files button, it said my iPad is using JPEG instead of JPG…
This is discouraging… I wanted to upload the graph result of WiFi Analyzer to show the signal strength and the WiFi speed from the S21 Ultra…
- FURRYe38Jul 19, 2022Guru - Experienced User
Try the camera icon and see if the file will upload. i recommend using .png or .pdf files
- CrimpOnJul 19, 2022Guru - Experienced User
The Browse option is pretty clear:
Those are the choices: jpg, gif, png, pdf.
There appear to be multiple method to convert a JPEG image into one of these formats:
https://www.igeeksblog.com/how-to-convert-photos-to-pdf-on-iphone-ipad/
This person seems to think it might be a "setting":
https://www.macobserver.com/tips/how-to/how-to-convert-iphone-photos-jpg-format/
- AnzenchitaiJul 21, 2022Aspirant
My dilemma is when I use the WiFi Analyzer to check on the signal strength, it pops up and down where as my neighbors WiFi are all non-movable graph result. Now my worries are the quality and the stability of the signal and the communication speed. I m sitting in the living room with my 6E router and my S21 Ultra is showing I have 1.8Gbps speed connection. But I m waiting for the Cable technician to come in to install the new modem for the 1Gbps account upgrade. Are there something wrong with my phone too? This is all so confusing…
