Anzenchitai
Jul 19, 2022Aspirant
RBKE963 too slow
My WiFi 6E system is using the latest firmware and I have changed the channel to the less congested channel. Everything was fine right after changing the channel. But after a day or so it is very slo...
Jul 19, 2022Guru - Experienced User
What actual speeds are you getting?
are you testing over 2.4ghz? 5ghz?
do wired speeds drop?
- AnzenchitaiJul 19, 2022Aspirant
Is there a way to setup the RBKE963 and SRR90 to auto reset everyday at 4am? I think resetting the router will help flushing memory and keeping the network faster. Yes, I m using 2x routers and 2x SSID with 1x cable modem. ISP is providing 2x IP for me.
Thanks in advance.
- FURRYe38Jul 19, 2022Guru - Experienced User
IF you mean reboot? Try a power timer.
Otherwise no. If your having to reboot the system, mean there is something wrong. Normally reboots every so often is not needed.
Are you seeing problems?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What CAT# LAN cable are you using?
What channels are you using on the RBKE and SRR systems?
I use a CAX80 and have had my 8 and 9 series online at the same time. No issues.
- AnzenchitaiJul 21, 2022Aspirant
Hello, today ISP installed Shaw Fibre+ Gateway 2.0 (XB7). It is now in bridge mode, so there is no WiFi signal interfering my RBKE963 & SRR90. the 963 is having 1.2Gbps on 6E of RBKE963 and 585Mbps on SRR90. These are the numbers I got from my S21 Ultra. Here are the results from fast.com… 380mbps on SRR90, and the RBKE963 is 600Mbps on both the router and the IoT. I have PN # and FCC ID, IC and a few different MAC #. Please specify which info you requrie from the label of the modem. It is 15h pst. I will do a scan with WiFi Analyzer tonight when everybody is at home and using internet. That is the most congested time and I have purchased and installed and Outside Extender on my SSR90 for my do walk the dog.
Thanks in advance.
