Boji
Jan 07, 2022Follower
RBKE963 WAN redundancy
The RBKE963 has 10G internet port and 2.5G ethernet port. Can I feed internet from two separate ISP to them simultaneously to create internet redundancy in case one fails? Would one work as prime and...
Jan 07, 2022Guru - Experienced User
The 2.5Gb port is a LAN side port only. Not a WAN port. There is only 1 WAN port which is the 10Gb yellow WAN port. Home class routers usally don't support WAN side redundency. So you'll not see that in home class products. Business and Enterprise products, you would see this more often.
