ptf2
Jun 24, 2022Follower
RBKE963 Wired Satellite Connections
I have a 3 story home (approx 4000 sq. ft.) with gigabit internet. I’ve just purchased the RBKE963 mesh kit, and I’m planning on installing the router on the ground floor near the modem and connectin...
Jun 29, 2022Guru - Experienced User
Any progress on this?
ptf2 wrote:
I have a 3 story home (approx 4000 sq. ft.) with gigabit internet. I’ve just purchased the RBKE963 mesh kit, and I’m planning on installing the router on the ground floor near the modem and connecting it's 10Gbps port to the modem's 2.5Gbps WAN port. Since the 2 satellites will be on 2 other floors of the house, I was planning on using existing CAT6 cabling in the house to connect one satellite to the router's 2.5Gbps port and the other satellite to one of the router's 1Gbps Ethernet ports. My rational was that this hardwired setup might provide better backhaul throughput than using the 5GHz WiFi backhaul channel when the satellites are separated by the distances (& building materials) involved in my setup. Two questions:
1. Is this reasoning sound due to the distances involved?
2. Would this free up the 2nd 5GHz radios in the router & satellites for additional 5GHz connectivity/throughput, or is it always “reserved” for a backhaul channel even if the satellites are hardwired to the router?
