GordonF-NYC
Dec 14, 2023Aspirant
RBKE963B - Ethernet Backhaul with AP Mode
Hi Everyone, I've been using Apple's AirPort Wi-Fi system for the past 10 years or so, quite reliably to be honest, but ancient technology by today's standards. I had 4x Airport Extreme Base Sta...
Dec 14, 2023Guru - Experienced User
Does other devices have problems connected or is it only Apple devices? Reason for asking is that there are some known issues on Apples iOS 17 Wifi section that are causing problem coming down the grape vine. If your Apple devices were updated recently and now your experiencing this, I'd make contact with Apple support. I have my 960 series online, router mode, however both RBS ethernet connected and a iPhone 12 Pro Max iOS 16.5 and have not experience any issues. Been holding back on updating to iOS 17 due to a different issue, however with other users posting issues with Apple devices and recent iOS 17, I'm holding out for Apple to address this.
️Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
Also, how are the RBS ethernet connected to the system? You say you have the RBS connected to the ISP router? If so, this is not correct for there connection. They need to be connected behind the RBR like this:
ISP Router<RBR960<>RBS960.
- GordonF-NYCDec 14, 2023Aspirant
Same thing here. Brand new Orbi 960 system. Spinning wheel on my phone and iPad. System is 4 days old. Wish I could be of more help, but there seems to be a lot of these types of issues plaguing the Orbi system.
Hey, thanks for the quick reply. Reviewing my connectivity, my Orbi router was connected to my switch through the yellow (internet) plug. I've reviewed the wiring diagram in the images you've provided, and they indicate that I should connect my Orbi router to my switch using the Ethernet plug.
I've tried this. However, this caused the internet to keep going in and out every couple of seconds. Speed tests would get hung up, resume, freeze, etc. I've rebooted the Orbit router, both satellites, as well as my Xfiniti modem/DNS server. After 15 minutes, the issue persists. As such, I've reverted back to connecting my Orbi router to my Xfiniti via the yellow "internet" plug.
The issue with my phone and iPad not connecting persists, unfortunately.
They are both iOS 17 indeed.
- FURRYe38Dec 14, 2023Guru - Experienced User
No, the RBS need to be connected to the LAN ports in back of the RBR. The Yellow WAN port on the RBR is still needed to be connected to the host router for that path. The LAN ports in back of the RBR can be connected to a LAN switch and then the RBS connected to this switch.
ISP Router<>RBR AP Mode>LAN Switch<>RBS connected to switch.
This is something I use in my configuration currently. I actually have 3 LAN switches daisy chained down to one RBS that's in the basement.
What is the brand and model of your switch you have currently?- GordonF-NYCDec 14, 2023Aspirant
Oh, that is not how I'm setup. My setup follows the 3rd image in this diagram:
Both of my RBS units are connected to my main Xfiniti router/DNS, and my RBR is also connected to the same Xfiniti router/DNS, as shown in diagram #3.
The funny thing is, now that I've connected that back to this configuration, I can't access http://orbilogin.net. It just forwards me to Netgear website. Fo figure!
