Talon38
Jan 20, 2022Tutor
RBKE963B - Help picking cable modem for Spectrum
I purchased a New Orbi 6E kit and have it installed. I would like to replace the Spectrum CM with a new model that will match the Orbi system as Spectrum increases its speeds from 1 G to 2-5G to 10G...
- Jan 20, 2022
the fastest modem right now is the CM2000 which has a 2.5g port.
I haven't seen any 5g or 10g ports on consumer modems (and the ISP's don't support that on docsis 3.1)
CrimpOn
Jan 20, 2022Guru - Experienced User
one port rather than port aggregation.
If you get telephone service from Spectrum, the modem must include that feature.
Talon38
Jan 20, 2022Tutor
Thanks! We d/c'd our home phones due to quack callers (40+ per day) and now use cell phones and RoboKiller (great software BTW), so only need the modem.
Cheers!
- plemansJan 20, 2022Guru - Experienced User
- CrimpOnJan 20, 2022Guru - Experienced User
Spectrum's approved modem list is here:
https://www.spectrum.net/support/internet/compliant-modems-spectrum-network
(Click on the 1G DOCSIS 3.1 heading.)
Picking a model with a 2.5G compatible port is probably a good "future proofing" idea.
- Talon38Jan 20, 2022Tutor
Thanks, what do you think of the RAX80? It's a router (I don't need) and a CM up to 6G. Mike
I ordered the CM2000. Thanks again,
Talon38
- FURRYe38Jan 20, 2022Guru - Experienced User
Good Modem.
Let us know how it all works out for you.
