bouchi
Jul 09, 2022Tutor
RBKE963B & Outdoor Satellite
Hello, I'm thinking about buying a new Orbi WiFi 6E RBKE963B pack and and want to know if Orbi outdoor satellites are fully compatible in a mesh network configuration ? I'm not able to find out...
- Jul 09, 2022
bouchi wrote:
Hello,
thank you very much for your fast and complete answer.
As I'm not yet an Orbi user, could you please tell me what the Orbi mode provide more than a Mesh extender ?---Orbi mode basically the router has more control between router/satellites to help with daisy chaining/star topology. It also seems to be a little smoother on smart roaming (subjective from me) even though its the device itself that decides when it roams between router/satellites.
If you can advise me based on your experience, what will you do ?
1. Buy RBKE963B + RBS50Y (or RBS50Yv2) and running in the mesh extender configuration ?
2. Buy RBKE963B only and wait for a potential WiFi 6E Orbi outdoor ?
3. Buy indoor and outdoor full compatible WiFi 5 Orbi system (AC3000, Orbi Pro WiFi 5 (SRK60B03)) until WiFi 6E will be generalized or replaced by WiFi 7 ?
Thank you
Bouchi
Are you needing the boost in speed/coverage? If it was me, I'd try the RBKE system with an outdoor extender. But I'd buy from somewhere with a generous return policy. that way if it doesn't provide the coverage/needs that you expect from the price, then you could return it and go with a standard AC system. I've used both the RBK53 and have the RBKE963. And I have a RBK50Y that I used with my RBK53. Do I notice much difference from going from an AC system to an AX system? Not really unless I'm speedtesting.
Jul 09, 2022Guru - Experienced User
Would it connect to your system in orbi mode? No.
But you can connect it in extender mode and run it with the same ssid since its a mesh extender.
would it be as efficient in its roaming performance? Unknown as I haven't tried it.
Netgear doesn't tell us updates about upcoming products
