kemcfarling
Jan 24, 2024Aspirant
RBKE963B Frequent buffering with streaming
Recently upgraded from a Nighthawk router to #RBKE963B MESH. I never had any buffering issues with the Nighthawk, but have had frequent buffering issues while streaming (e.g. Netflix, Amazon) since t...
- Feb 01, 2024
Sorry for the delay in responding - yes, disabling traffic monitoring did the trick. Thank you again for the assist!
Jan 25, 2024Guru - Experienced User
What modem/gateway is the orbi connected to?
is the tv/receiver hardwired into the router or one of the satellites?
is ipv6 enabled?
What actual speeds do you pay for and receive?
Reason I ask this is some services such as netflix/amazon dynamically change your resolution. If you have a better connection, it might be negotiating a faster speed that your service isn't capable of.
It could also be the modems connection if its hardwired in. So its good to check that.
kemcfarling
Jan 25, 2024Aspirant
Very thoughtful questions - I'll take a look in those areas. Thank you very much!
