kemcfarling
Jan 24, 2024Aspirant
RBKE963B Frequent buffering with streaming
Recently upgraded from a Nighthawk router to #RBKE963B MESH. I never had any buffering issues with the Nighthawk, but have had frequent buffering issues while streaming (e.g. Netflix, Amazon) since t...
- Feb 01, 2024
Sorry for the delay in responding - yes, disabling traffic monitoring did the trick. Thank you again for the assist!
kemcfarling
Jan 25, 2024Aspirant
What modem/gateway is the orbi connected to?
Arris S33 cable modem; the modem is plug directly to the Orbi router.
is the tv/receiver hardwired into the router or one of the satellites?
The TV/receiver (Onkyo TX-NR686) is hardwired to a CISCO SG102-24 switch. The switch is hardwired to the Orbi router.
The TV/Receiver is operating using the most current Onkyo firmware.
is ipv6 enabled?
Yes
What actual speeds do you pay for and receive?
948 Mbps down, 24 Mbps up
owlyn
Jan 25, 2024Luminary
Make sure that Traffic Meter is turned off.
- owlynJan 26, 2024LuminaryDid turning off traffic monitoring fix it?
- kemcfarlingFeb 01, 2024Aspirant
- FURRYe38Feb 01, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
