apb0703
Jul 30, 2023Follower
RBKE963B with 2 Sataellites Sorry,your timestamp is expired. Please click the menu to re-enter the
Hello. I recently hooked up the Orbi 960 Series Mesh with 2 satellites. I am having some issues with the device and I have reset it twice. I tend to work in the WUI over the App because I like to set...
Jul 31, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What browsers are you using?
What PCs are you using?
When you say static, do you mean setting an IP address reservation ON the RBR?
