maxne
Dec 19, 2021Tutor
RBR 350 Internet connection sporadically interrupted
I have an "askey rtl 6300" 5G outdoor router. For some time now, the Orbi has been losing the internet connection. The LED ring lights up purple. A normal software restart does not help. I have to di...
Dec 20, 2021Guru - Experienced User
What mode is the ISP router working in? Router gateway or bridge? Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- maxneDec 21, 2021Tutor
Hi FURRYe38,
The ISP router is in the IP Pass-Through mode. It has no WIFI or DHCP funtion. SO the Orbi router gets the Internet IP Addr from the modem. I had in the night the same issue again and in the morning it was also not possibe to connect to the ORBI Webpage via LAN or WLAN. My device got an IP address from the Orbi. I had again unplug the Orbi
- FURRYe38Dec 21, 2021Guru - Experienced User
Ok, lets try this, set the ISP for router mode/remove the IP Pass thru feature or disable it. Set the RBR for AP mode. Connect the RBR to the ISP router using the RBRs WAN port to the LAN port on the ISP router...
