Retired_Member
Apr 14, 2022RBR 750 - ISP firmware
I am trying to update my RBR router. Current version is V3.2.20.1. Updates failing. Then i realize my version is ISP firmware. I am no more linked with iSP and contract is terminated. I would like to ...
- Retired_MemberApr 15, 2022I have teardown and find the serial pins on the orbi. I am planing to buy a usb to TTL 5 PIN serial converter and use PuTTY and TFTP64 program to take orbi in recovery mode and flash stock firmware
Apr 14, 2022Guru - Experienced User
Is this a NG retail system or did you get it from a ISP?
IF this is ISP FW which some ISP do handle, then you'll need to contact the ISP about FW updates.
You can try using TFTP and see if NG stock FW will load...
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.
Make sure you enable tftp: https://www.thewindowsclub.com/enable-tftp-windows-10
Video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done:
https://www.youtube.com/watch?v=R9DLrLQrpaw
I had a problem on a Windows 10 PC where this didn't work to use TFTP, so I switched to a Windows 7 PC and the TFTP worked.
Try nmrpflash:
https://github.com/jclehner/nmrpflash
Retired_Member
Apr 15, 2022Its a ISP provided Orbi. The current firmware is from ISP I believe. All the setting and login pages are same expect the ISP logo. There wont be any firmware upgrades from ISP and i am unable to syn any satellite from NG. Since versions are different. Thats y i want to install stock firmware. I am unable to get the orbi to tftp mode to
Accept the files. ( unable to get power leds to light orange and flashing)
- FURRYe38Apr 15, 2022Guru - Experienced User
If that failed, I would return the Orbi system back to the ISP.
You'll need to find a different system then. Something Retail and not ISP developed.
- Retired_MemberApr 15, 2022This is the login page. GUI. The device is same as retail onces. There should be some way to program it.
- CrimpOnApr 15, 2022Guru - Experienced User
Retired_Member wrote:
This is the login page. GUI. The device is same as retail onces. There should be some way to program it.There definitely is a way to reprogram the router, but it is so difficult that cutting your losses and buying a new router is the more sensible alternative. Netgear routers have pins for a serial (RS232) interface on the internal circuit board. A USB to serial converter is under $20. But then you have to learn how to access the underlying U-boot and Linux systems from a command window and figure out what to change. Could be 100's of hours of learning curve. Meanwhile.... no internet.
A clever person discovered how to change an RBR50 into an RBS50 by using telnet to alter one parameter in the ROM. Since that hack was discovered several years ago, it has not been repeated with any other Orbi model. (Lack of interest? or... too hard? no one knows)
Verizon did a similar thing with the original RBR50 systems. Sold them to customers with promises of support, and then never updated the firmware. Not once.
