Retired_Member
Apr 14, 2022RBR 750 - ISP firmware
I am trying to update my RBR router. Current version is V3.2.20.1. Updates failing. Then i realize my version is ISP firmware. I am no more linked with iSP and contract is terminated. I would like to ...
- Retired_MemberApr 15, 2022I have teardown and find the serial pins on the orbi. I am planing to buy a usb to TTL 5 PIN serial converter and use PuTTY and TFTP64 program to take orbi in recovery mode and flash stock firmware
CrimpOn
Apr 15, 2022Guru - Experienced User
It is not clear (to me) that the power LED flashing orange is a requirement to flash firmware. I have not done this for a while, so my memory is a bit fuzzy. I recall that using TFTP was timing sensitive. Starting the TFTP transfer a second too soon, or a second too late, and it failed.
This program handles the timing automatically: https://github.com/jclehner/nmrpflash
Notice that (unlike the Netgear instructions for TFTP) the instructions for this program make no mention of the power LED light.
I am not optimistic that even nmrpflash will succeed because I fear that the ISP doctored the firmware to make it refuse to load stock firmware.
Retired_Member
