henry0111
May 09, 2022Aspirant
RBR 750 - router showing offline + ios devices cannot load certain websites
Hello, Since last week, I noticed that my iOS devices cannot load certain websites like Google, Youtube, App Store, Gmail. This happened only when my iOS devices connected to Wifi. When I sw...
May 10, 2022Guru - Experienced User
Be sure to review this as well:
- henry0111May 10, 2022Aspirant
This is the model# of the Internet Service Providers modem. Quite sad that my router gone offline regularly but my satellite stay online.
I will try to disable WiFi Private IP address and Limit IP tracking features on my iOS devices, see whether this will work when connecting to Wifi.
- FURRYe38May 10, 2022Guru - Experienced User
What mode is your modem working in? Router or Bridge mode? This model # reports it having a router and wifi built in.
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
