ricci1
Jun 04, 2024Tutor
RBR 750 / 3 RBS Satellites
Hello - Purchased kit from Costco back in 2021. Using fidium fiber 1g symmetrical with 3 RBS 750 satellites on 5k SQF, 2 floors. I am not sure on the ONT gateway model. System has been working st...
Jun 04, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Try turning OFF one RBS.
ricci1
Jun 05, 2024Tutor
Thank you for responding FURRYe38
V4.6.9.11
DZS 2424GN GPON ONT
I Assume this is the case. ONT was placed in my garage. Ethernet runs inside the wall from garage to control room on second floor. 30 foot run +/- . Cable was installed by home builder.
There are two satellites 40 feet from router. The third unit is on outside porch in a weather enclosure . Outdoor unit support signal for back porch were we spend a significant amount of time. outdoor unit is 29 feet from one of the satellites on the outdoor area. There is glass and brick in between .
I have not checked by disconnecting satellites.
This happens with all my devices connected to main wifi, iPhones, iPad , echo dots, fire sticks all loose connectivity.
wireless setting general - from orbilogin.com
region- North America
2.4 GHz channel Auto (3)
2.4 GHz wireless mode - Up to 573.5 Mbps
5 GHz channel 36 + 40 + 44 + 48(p)
5 GHz wireless mode up to 1201 Mbps
Yes one in every direction. Side neighbors are 50 feet away to each side. Front neighbor 75 feet away.
Has a factory reset and setup from scratch been performed since last FW update?Yes
Yes -
- FURRYe38Jun 05, 2024Guru - Experienced User
V4.6.9.11
DZS 2424GN GPON ONT
Just a ONT here, no built in router and wifi.
I Assume this is the case. ONT was placed in my garage. Ethernet runs inside the wall from garage to control room on second floor. 30 foot run +/- . Cable was installed by home builder.Can you take a look at the cable to see the markings on the cable? Should give CAT# printed in the cabling.
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.There are two satellites 40 feet from router. The third unit is on outside porch in a weather enclosure . Outdoor unit support signal for back porch were we spend a significant amount of time. outdoor unit is 29 feet from one of the satellites on the outdoor area. There is glass and brick in between .
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰Does this happen with the RBS turned OFF?
Please try this if you can get some time to check this to see if the RBR alone stops WiFi signals
Does this happen with both wireless and wired devices?This happens with all my devices connected to main wifi, iPhones, iPad , echo dots, fire sticks all loose connectivity.
What channel configurations are currently set on the router?wireless setting general - from orbilogin.com
Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 channel on 5Ghz.
Has a factory reset and setup from scratch been performed since last FW update?YesYes -
There is FW past v4 that you might consider as well. Try some of the suggestions first then lets go from there.
