Tooheycohen
Apr 16, 2025Aspirant
RBR 750 access control blockeed all devices
I logged in to my router via desktop computer and accidentally turned on Access Control and blocked all my devices from the router. I cannot login to router page to allow access. I am using my gues...
- Apr 16, 2025
Can you connect a different PC or laptop that has never connected to the RBR and see if you can get in that way?
Or if you can access the RBRs web page thru the phone in a phone web browser, log in then try to disable AC there...If all fails, you'll need to factory reset and setup from scratch.
Apr 16, 2025Guru - Experienced User
Tooheycohen
Apr 18, 2025Aspirant
Thank you for replying to my query. I ended up having to factory reset the router. I had no problems, and so far so good. 🙂
- FURRYe38Apr 18, 2025Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
