Jonnybunker
Nov 22, 2020Guide
RBR 750 and 2 RBS 750 - All devices Connecting to Router Only
I was doing some troubleshooting on something compeltetely unrelated, but then realized that all of my devices are showing connecting to only my main Router, the RBR750. I have checked both the satel...
Nov 22, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
What do you see if you log into the RBS web pages?
Test this by taking a mobile device near the RBS. Turn OFF the wifi radio on the devices for 5 seconds then back on. Then check the RBS web page.
Try disabling Armor...
Jonnybunker
Nov 22, 2020Guide
Sorry , forgot those details !
Here is setup :
Firmware V3.2.16.6_1.4.4
3 story house , 2950 sq feet , built 2019
Main Router up on 3rd floor master closet- east side of house , where modem is (I know probably not ideal)
RBS750 on 2nd floor, west side of house
RBS750 on 1st floor , east side of house
Disabled Armor to test and will try the other troubleshooting as well! Attached the router firmware and this matched the Satellite Firmware when I checked earlier. Did a “check for new” but didn’t find anything
Thanks foe the help !
The odd thing is when I logged into Armor , it showed a ton more devices connected than my Orbi app was displaying. Rebooting router now to see if armor being disabled fixes
Here is setup :
- FURRYe38Nov 22, 2020Guru - Experienced User
Be sure to power OFF the RBR after disabling Armor then back ON after 30 seconds.
Try turning down the power output of the RBR as well.
- JonnybunkerNov 22, 2020GuideSorry missed your 2nd reply- they are probably about 25-35 feet from each other but i haven’t walked the exact distance- 1sr satellite is probably a bit closer.
- FURRYe38Nov 23, 2020Guru - Experienced User
25ft is a bit too close.
- JonnybunkerNov 22, 2020GuideUpdate -
Turned off Armor-
Rebooted Main Router and manually rebooted the satellites , as still only one was showing devices.
Once doing a few reboots on each unit and the modem itself , things finally seemed to return to normal.
I am not sure if the individual reboots fixed the issue or if disabling Armor.
Do we think that it was Armor ? I know that I have seen other threads where it was causing problems , but wouldn’t that be strange if Armor was completely disabling the capability of the satellites working ?- FURRYe38Nov 23, 2020Guru - Experienced User
Well you can re-enabled it again and see if the problem returns, if it does, then you'll know. Just disable it again.
Something to post about in the Armor forum:
https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor
