OakenOne
Mar 04, 2022Aspirant
Rbr 750 and powerline
I have a recent Netgear Orbi RBR750 which connects to my BT Home hub 5 and works as expected I have a TP-Link TL-PA4020PKIT 2-Port Passthrough Powerline which works when connected directly to my BT...
Mar 04, 2022Guru - Experienced User
Is the orbi right next to the hub and using the same power circuit?
OakenOne
Hi,
Yes they are next to each other and on the same circuit.
All I did was disconnect the Ethernet connector of the powerline from the BT Home hub and connect it to the Orbi. Then I lost the signal down powerline. When I plug the ethernet cable back into the BT Home hub it worked.
If I plug a laptop into the same Orbi ethernet port it works so I know that it works.
Thanks
Thanks
