OakenOne
Mar 04, 2022Aspirant
Rbr 750 and powerline
I have a recent Netgear Orbi RBR750 which connects to my BT Home hub 5 and works as expected I have a TP-Link TL-PA4020PKIT 2-Port Passthrough Powerline which works when connected directly to my BT...
OakenOne
Hi,
Yes they are next to each other and on the same circuit.
All I did was disconnect the Ethernet connector of the powerline from the BT Home hub and connect it to the Orbi. Then I lost the signal down powerline. When I plug the ethernet cable back into the BT Home hub it worked.
If I plug a laptop into the same Orbi ethernet port it works so I know that it works.
Thanks
Thanks
