Edelmann
Apr 27, 2024Aspirant
RBR 750 and Ring Spotlight Pro Cam
Hello, I'm having trouble connecting the Ring Spotlight Cam Pro to the WiFi. Unfortunately, Ring Support couldn't help me and said I should send the cam back. I also have a Ring Doorbell Pro in o...
CrimpOn
Apr 27, 2024Guru - Experienced User
This product supports both 2.4G and 5G WiFi:
https://ring.com/support/articles/ul24r/Spotlight-Cam-Pro-Information
I have not found the installation instructions (yet), but that red/blue blinking thing sound very much like the setup process is hung.
- EdelmannApr 27, 2024AspirantHi,
Yeah they say, that they support 2,4 an 5 GHz. But I searched a little bit in the internet and some meant, you should try the IOT WiFi with 2,4 ghz only.
Never had any problems with any devices to connect with my WiFi.- CrimpOnApr 27, 2024Guru - Experienced User
The setup instructions do not mention red/blue blinking:
At which step in the setup does it fail?
- EdelmannApr 27, 2024AspirantGuess at the last step. There i have to choose my WiFi and password. Then it says „sorry a problem occurred, can’t connect to your WiFi.
