Edelmann
Apr 27, 2024Aspirant
RBR 750 and Ring Spotlight Pro Cam
Hello, I'm having trouble connecting the Ring Spotlight Cam Pro to the WiFi. Unfortunately, Ring Support couldn't help me and said I should send the cam back. I also have a Ring Doorbell Pro in o...
Edelmann
Hi,
Yeah they say, that they support 2,4 an 5 GHz. But I searched a little bit in the internet and some meant, you should try the IOT WiFi with 2,4 ghz only.
Never had any problems with any devices to connect with my WiFi.
CrimpOn
Apr 27, 2024Guru - Experienced User
The setup instructions do not mention red/blue blinking:
At which step in the setup does it fail?
- EdelmannApr 27, 2024AspirantGuess at the last step. There i have to choose my WiFi and password. Then it says „sorry a problem occurred, can’t connect to your WiFi.
- CrimpOnApr 27, 2024Guru - Experienced User
Does the Ring app show the password, or is it one of those things that only shows 'dots'?
I'd suspect a typing error, since the correct WiFi network appeared in the list of available systems.
- EdelmannApr 28, 2024Aspirant
Yeah, it just Shows dots. Gut also tried to put in a wrong password, then the Camera shows a red light. It is for sure the right password, because i see the new ring device online in my device Manager in the Orbi App.
