Sford0125
Sep 09, 2022Aspirant
RBR 750 and two satellites
The satellites have Wi-Fi and working but the main router says no connection and pink light. I am ready to scream and spent 8 hour following all these instructions to no avail
Sford0125
Sep 10, 2022Aspirant
Also when I attempt to contact to the ORBI wifi, it states that it has no internet access. So, I am at a loss.
ekhalil
Sep 10, 2022Master
Pink light on the Orbi router means it’s not detecting internet:
1. Please make sure the cable between the ARRIS modem and Orbi is not faulty.
2. Please make sure the cable from the modem is connected on the yellow WAN port in the Orbi router.
3. Try to switch off and then on the cable modem and then do the same for Orbi router.
When the Orbi router detects internet the pink led should go off.
- Sford0125Sep 10, 2022AspirantIt appears all is attached again. I have ordered another satellite for another room just to make better. The pink light went off and my app is showing that it all works.
