lisakc
Apr 03, 2022Tutor
RBR 750 Daisy Chain
I was just told that my RBR 750 and ALL Orbi wifi 6 mesh systems do NOT support a Daisy chain topology. There is no way for me to enable this feature when logging into the router. Does anyone have an...
Apr 04, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
lisakc wrote:
I was just told that my RBR 750 and ALL Orbi wifi 6 mesh systems do NOT support a Daisy chain topology. There is no way for me to enable this feature when logging into the router. Does anyone have any current info on this topic? I have updated to current firmware V4.6.5.14_2.0.54, do NOT have the armor security. Router on second story, satellites on first story.
Thank you!
