osmall
Apr 25, 2022Aspirant
RBR 750 dropping internet after lease expires, every 2-ish hours
I have an RBR750 (and two satellites that are currently disconnected to help with diagnostics) on xfinity. Prior to this event, everything had been working fine with no drops for about a year. We r...
- Apr 26, 2022
You may want to try updating FW then:
osmall
Apr 26, 2022Aspirant
The RBR does not show a pink light. On the home status page, internet says waiting. I just did a full factory reset and setup from scratch. It was connected with a 5E, but I made a new Cat 6.
Other updates:
I was able to get my Linksys 1900 ACS router to work just fine, accept renewals etc. No major changes, just started working.
The Orbi still loses internet connectivity at the end of the lease, or whenever I try to renew. I can now use release/renew (on connection status) to get internet to work without power cycling the modem.
Apr 26, 2022Guru - Experienced User
