dklb0711
Oct 03, 2022Aspirant
RBR 750 gives message of can't connect to this network
We have a RBR 750 with 2 satellites. I have recently switched jobs and received a new HP Z Book. I can connect to our ATT&T wifi with the new computer with no issues, but when I attempt to connect to...
- Oct 03, 2022
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry option #2 first...
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
CrimpOn
Oct 03, 2022Guru - Experienced User
dklb0711 wrote:
I get the message "can't connect to this network".
HP Z Books run Windows. What does the Windows Network Troubleshooter say about this?
It is not clear (to me) whether this message:
- This message comes from the router, "I am rejecting your attempt to connect", or
- This message is reported by Windows.
Can you attach a screen shot?
dklb0711
I was just now able to connect, I think it had to do with something in Cisco. As soon as I entered the pw there it linked right in.
