dklb0711
Oct 03, 2022Aspirant
RBR 750 gives message of can't connect to this network
We have a RBR 750 with 2 satellites. I have recently switched jobs and received a new HP Z Book. I can connect to our ATT&T wifi with the new computer with no issues, but when I attempt to connect to...
- Oct 03, 2022
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry option #2 first...
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
dklb0711
House is about 3900 sqft. The 1st satellite i sin the master bedroom roughly 40+ feet away, the second satellite is upstairs at probably 60+ feet away.
I believe it may have been a Cisco issue of not logging on through that program on my computer. As soon as I did that I could get in. It was kinda weird as I've always been able to login through the available networks in settings.
Oct 03, 2022Guru - Experienced User
Ok sounds like you got it fixed. Keep that in mind.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
